Big Sur Public Beta - iCloud error
madvinegar
123
33
28
Greece
This is the message I get when trying to connect to iCloud with my Apple ID.
Anyone else experiencing the same thing in Public Beta? I believe it must be a bug.
Other than that, I can connect normally to the app store and to my apple ID. It is just the iCloud that has the problem.
And it just says "cannot communicate with server". Nothing to do with a verification error etc...
Reactions: irisbroken
I Have same problem. After entering the verification code the popup appears. And I tried to register but it still couldn't.
Ryzen 3600
Aorus B450I Pro Wifi
2x16GB Geil Orion AMD Edition 3000mhz oc 3600mhz
Sapphire RX 570 4GB ITX
Wifi Intel Wifi AC-9260
Opencore 0.6.3
Big Sur RC 2
No issues here. Did you have iCloud services like iMessage etc setup before? If not try generating new serials.
Hey there! Big Sur run smoothly on my machine, but I have faced the same issue. Tried generating new serials to no avail.
Would appreciate any kind of advice. Should I try generating serials using different Macs a few more times?
I used this iCloud account with Catalintosh previously on the same machine and it was working fine :(
I have same problem :(
Same problem, but I have fully operating Catalina on same PC as backup solution. Didn't want to take a risk for multiple attempts.
make sure your network controller is built-in
Reactions: Gigamaxx
