how to fix bluetooth
jayone
6
5800U amd
hi,I have update to Tahoe but the bluetooth can not work which made me crazy
I already use usb tool to map the usb port
but the bt works sometime and dont work sometime. it seems random...
HS04 HS03 sometime can show rate when bt works
Which WiFi/Bluetooth device are you using?
How is it mounted, on a PCIe card or in a motherboard M.2 connector?
it is ax200,I have used oclp-mod to patch the system so I can use airportitlwm to replace itlwm.
this night I rollback , It seems works now
so may the problem is oclp-mod?
Are you using the Ventura version of the Airportitlwm.kext v2.3.0, which I understand is required when using OCLP-Mod to get the Intel WiFi working?
With regards the Intel AX200NGW's Bluetooth module, you will need to be using the following kexts (Latest versions):
  1. BlueToolFixup.kext
  2. IntelBluetoothFirmware.kext
  3. IntelBTPatcher.kext
Plus have the following NVRAM Add & Delete entries in your config.plist:
Screenshot 2026-06-20 at 18.16.15.png as viewed in ProperTree plist editor
A zipped copy of the Bluetooth NVRAM entries is attached below.
View attachment 19430 as viewed in ProperTree plist editor
thanks a lot
