how to fix bluetooth
jayone
5
5800U amd
hi,I have update to Tahoe but the bluetooth can not work which made me crazy
I already use usb tool to map the usb port
but the bt works sometime and dont work sometime. it seems random...
HS04 HS03 sometime can show rate when bt works
Which WiFi/Bluetooth device are you using?
How is it mounted, on a PCIe card or in a motherboard M.2 connector?
it is ax200,I have used oclp-mod to patch the system so I can use airportitlwm to replace itlwm.
this night I rollback , It seems works now
so may the problem is oclp-mod?
