Sanity Check for macOS High Sierra
er0
AMD Ryzen 7 5800X
Hello, I think my System should work, but to be sure I want to ask the Pros :P
CPU : AMD Ryzen 7 5800X 8x 3.80GHz
GPU : Nvidia GTX 1060 6GB
Motherboard : Gigabyte B550 Aorus Elite V2
Memory : 16GB Crucial Ballistix schwarz DDR4-3600 DIMM CL16 Dual Kit
Please let me know if this will work, with High Sierra or another macOS version. I need 3D Acceleration.
Thanks a ton, genuinely appreciate it.
Hello, I think my System should work, but to be sure I want to ask the Pros :p
did you get some testing on it?
