@AudioGod
thank you for your reply. I tried imacpro1.1. But I got this error message.
I know my gpu is not compatible. I wanted to reach install acreen. I am trying to install Big Sur 11.5.2
@AudioGod
You would need to disable above 4G in the bios and add the boot argument npci=0x2000, Disable the SecureBootModel in the config.plist but I doubt very much you will be able to boot into BigSur anyway using that gpu.
High Sierra or bust I’m afraid,
@AudioGod
Disable above 4g like audiogod mentioned then Disable the TPM module if you have one and clear the key. Or if you don’t have one installed, switch from software to hardware dedicated TPM will disable it. Give it another try.
Please have someone USBmap KEXT for Crosshair VIII dark Hero ? Thx
I do yes, I will send it to you later on today when I’m back home. 👍
Reactions: Pabo
After turning off the PC, it started again after a few seconds. I had to solve it by disabling in BIOS Advanced -> APM Configuration -> Power On by PCIe -> Enabled. After disabling it is turned off OK. I still deal with sleep work. But he won't fall asleep, but freezes. It must then be restarted by deleting CMOS. Will it be about I don't have a mapped USBMAP?
Yeah, that setting seems to have upset shutdown since 4010 for some users. Strangely though it doesn’t effect my setup at all.
Il mark it as disabled from the next update to play it safe for everybody.
Reactions: Pabo
Looks like BIOS 4021 is out, I'll give it a try and see if any issues crop up.
I have been using it since it released A few days ago. All working fine. 👍
Reactions: gatorchamp85
No that sounds like a different kind of problem to me.
Here's the mapping for a Dark Hero anyway, See if it helps at all.
Sorry I didn't send it to you sooner but it totally slipped my mind.
Reactions: Pabo
I tryed but it did not work. I will buy an RX 6XXX AMD GPU. I hope GPU prices down soon :)
Thanks, it works well, but I still have to fix the non-working sleep ......
I just saw 4021 and updated this morning. It works well so far.
Reactions: AudioGod
Have you tried simply resetting your NVRAM?
Also what NVMe‘s are you using in your system?
Other things to try, Bring the system down to barebones and remove all USB devices internal and external bar your keyboard and mouse and test from there. If it works slowly put stuff back testing sleep every step of the way until fails and then you will know what’s causing it.
Reactions: Pabo
1x M.2 Gigabyte 1T. MacOs Big Sur 11.5.2
1x M.2 Samsung 980 500 GB (Win 10)
OK, I'll try everything you write. Then info .... thank you
AudioGod,
Just saw Beta 6 came out. Any word if it is working with the current EFI for Beta 5?
AudioGod,
Im not seeing the Update on my end yet.
Are you able to view the update on your system?
I saw it on my dev channel. Not public beta yet.
