There are 3 different types of B550 MB here, MSI B550 Unify, MSI B550 Unify X, and Colorful Battle AX B550. CPUs are 5600X and 5800x.
Last year (2022) I proposed to use them as office desktop with MacOS, however I didn't know this is a long darkness way.
With help from @Edhawk in post below, Big Sur installed on MSI B550 Unify. Thanks again. However BlueTooth not working made it totally useless.
forum.amd-osx.com
Why BT is so important to me? I use TouchPad for many years (since 2012 MBP), and familiar with iPhone/iPad and Mac working together. Currently I am using a Z170/i5-6500 Catalina Hackintosh, it works perfectly with my iPhone and iPad.
To solve BT issue, I searched lots of posts and tried many times and then realized it is not possible with a USB3.0 device which I didn't have until yesterday.
So I use Colorful MB and 5600X try to install Monterey since I got USB3.0 Flash disk. Detailed specs are:
CPU: AMD Ryzen3 5600X
MB: Colorful BATTLE-AX B550M with Ethernet RTL8111 and Audio ALC662
Memory: 16GB*1 DDR4 3200
HD: WD SN750 1TB NvME SSD * 1
Graphic Card: SAPPHIRE RX560
Wifi/BT: BCM94360
BIOS upgraded to the newest version which is "BATTLE-AX B550M-HD PRO V14 BIOS 1009 (date 2022-07-19)"
BIOS settings by following https://dortania.github.io/OpenCore-Install-Guide/AMD/zen.html#amd-bios-settings:
Disabled
Fast Boot
Secure Boot
Parallel Port
Enabled
Above 4G Decoding
OS type: Windows 8.1/10 UEFI Mode
Created USBmap.kext in Windows 10 on this machine via https://github.com/USBToolBox/tool
Installation flash disk:
USB 2.0, OpenCore 0.8.8-DEBUG, Monterey 12.6.3
OC config file revised by following dortania guide.
OK, seems everything is ready. Insert flash disk to MB, and boot.
Boom!
stuck at "Registered CoreAnalyticsHub functions with xnu."
Searched internet and no clue how to troubleshooting. Can anyone guide me next steps please? It would be much appreciated.
EFI attached. Screenshot will be posted in my reply.
MSI Unify X B550 problems
hi,guys! when I try to boot(install) Monterey 12.3.1 with OC, it was stuck, I don't know what's wrong, or I should choose Big Sur? pls help, thx! have a nice day! My build: MB:MSI Unify X B550 CPU:5900X GPU:6900XT DRAM:G.Skill 4000Mhz 16G*2 OC ver:0.7.9-RELEASE
Wifi/BT: BCM94360
Disabled
- Serial/COM Port
- Compatibility Support Module (CSM) (Must be off in most cases, GPU errors/stalls like gIO are common when this option is enabled)
- IOMMU
Fast Boot
Secure Boot
Parallel Port
Enabled
- EHCI/XHCI Hand-off
- SATA Mode: AHCI
Above 4G Decoding
Boom!
