UPDATED ON 14 JUNE 2026
MY SECOND AMD HACKINTOSH
and its working perfectly - big thanks to this awesome community
Supported macOS-Versions: macOS Ventura (13.7.8) √ / macOS Sonoma (14.8.7) √ / macOS Sequoia (15.7.7) √
(long term EFI-test for productivity)
MAINBOARD
ASUS ROG Crosshair X870E Extreme (BIOS 1715 AGESA ComboAM5 PI 1.2.0.3G)
(5"LCD FW0109 / ASM4242 FW250708 / ITE IT8857 FW0206GX / ALC4082 FW16 / Nuvoton NCT6701D / ITE IT8883FN-I/BX)
ROG-X870E-X
Realtek SupremeFX USB Audio (ALC4082) √
Realtek 5Gbit Network Adapter (RTL8126A) √
Aquantia/Marvell FastLinQ Edge 10Gbit Network Adapter (AQC113CS) √
MediaTek Wi-Fi 7 BT5.4 (MT7927) X (not supported in macOS) (removed from mainboard)
ASMedia USB4 (ASM4242) X (not supported in macOS)
VRM-Fan @ 2000 RPM fixed (PWM-Mode)
USB-Mapping
1x Front USB Type-C Port with switch (USB3.2)
U20G_C6 (1)
4x Front USB Type-A Ports (USB3.0)
U5G_E1234 (18)
2x Rear USB Type-C Port with switch (USB3.1)
U10G_C23 (12) / U10G_C22 (14)
5x Rear USB Type-A Ports (USB2.0/USB3.0)
U10G_4 / U10G_18 (2) / U10G_19 (11) / U10G_20 (13) / U10G_21 (5)
1x Internal USB 2.0 Port for Bluetooth
M.2(WIFI) (15)
1x Internal USB 2.0 Port for USB Audio
USB Audio (6)(16)
CPU
AMD Ryzen 9 9950X3D 4.3 GHz AM5
100-100000719WOF
iGPU AMD Radeon Graphics X (disabled in BIOS)
PBO-Enhanced (Level 1 90°C)
Curve Optimizer (All CCDs) UV-30
RAM
Kingston FURY Beast DDR5-5200 MHz 288-Pin 128 GB-Kit (4 x 32 GB)
KF552C40BBK4-128
(DOCP I configuration for 4 modules in dual channel running @ 4800 MHz / CL 40-40-40-80 / 1.25v)
PCI EXPRESS CARDS
Sapphire TOXIC AMD Radeon RX 6950 XT Limited Edition 16 GB √
11317-01-20G
(Riser PCIe-Slot)
OC-BIOS Mode running @ 2565 MHz Core speed
Thermaltake PCIe 4.0 Dual 90 Degree Riser Cable (130mm / black)
AC-071-CO1OTN-C1
(PCIe-Slot1) PCIEX16(G5)_1 (A)
Broadcom BCM94360CD √
6871658863422
(M.2 NGFF Slot) M.2(WIFI) (15)
DISPLAY
Dell 34“ Curved Monitor
S3422DW
WQHD 3440 x 1440 @ DisplayPort 100Hz
HP Series 5 Pro 34“ Curved Monitor
534PM
VSDisplay 14,5" Wide Display PC Case Monitor (white)
VS145ZJ01
HD 720 x 2560 @ HDMI 60Hz
SensorPanel Software:
Widgetter (macOS)
AIDA64 Extreme (Windows)
STORAGE
Internal
WD Black SN850X NVMe SSD 2TB (Windows 11 Pro 25H2)
WDS200T2X0E-00BCA0
(Storage Interface Socket 3) M.2_1 (7)
WD Black SN850X NVMe SSD 1TB (macOS Ventura 13.7.8)
WDS100T2X0E-00BCA0
(Q-DIMM.2 Slot) DIMM.2_1 (8)
WD Black SN850X NVMe SSD 2TB (macOS Sequoia 15.7.7)
WDS100T2X0E-00BCA0
(Q-DIMM.2 Slot) DIMM.2_2 (8)
WD Green SN350 NVMe SSD 2TB (Grub/OC-REL+DBG/OC-Test/Zorin OS/Acronis Rescue Boot macOS+WinPE/Gparted/OS-Installations)
WDS100T2G0C-00CDH0
(U.2 SFF-8639) SLIMSAS (10)
KingSpec P3 SSD 4TB SATA-3 (Games NTFS)
B0BKL4PQM2
(SATA-3 Port 1) SATA6G_1 (9)
KingSpec P3 SSD 2TB SATA-3 (Data ExFat)
B0BKL4PQM2
(SATA-3 Port 2) SATA6G_2 (9)
External
ORICO MacData Vault 4Big DAS Studio
9948C3
(USB 3.1 Gen2 + Hub) U10G_C22 (14)
Seagate Exos 7E10 8TB SATA-3 (Data-Backup ExFAT)
ST8000NM017B-2TJ103
(Slot 1)
Seagate Exos 7E8 8TB SATA-3 (System-Backups ExFAT)
ST8000NM000A-2KE101
(Slot 2)
Seagate Exos X22 22TB SATA-3 (Backups ExFAT + Time Machine)
ST22000NM001E
(Slot 3)
Crucial P5 Plus NVMe 2280 512GB (Portable-Data ExFAT)
MTFDKBK512QFM
(USB-C 40gbps - Thunderbolt 3/4 & USB 4.0 Enclosure - ORICO M234C3-U4-GY-BP-V1)
CASE
Thermaltake CTE C750 Air Snow Full Tower Chassis
CA-1X6-00F6WN-00
CABLES
AsiaHorse 16AWG Sleeved Cable Kit (300mm / white)
B0B4V8T8BD
Sleeved Cables for CPU (4+4-Pin) & Mainboard (24-Pin)
deleyCON 18AWG Sleeved PCIe Cable Kit (300mm / black & grey)
MK5570
Sleeved Cables for GPU (8+8+6-Pin)
PSU
NZXT C1000 Gold
PA-0G1BB-EU
CPU COOLING
Thermaltake TH420 V2 Ultra ARGB AIO Liquid Cooler Snow Edition (420mm)
CL-W407-PL14SW-A
(Back-Intake PUSH with 3x Thermaltake CT140 ARGB white - 140mm PC Cooling Fans)
Water pump @ 2200 RPM (PWM-Mode) / Curve (Trigger) 3300 RPM @ 70-95°C CPU Core-temp
-> Liquid-temps @ idle 24°C / normal 25-27°C / max 30°C
Radiator-Fans @ 700 RPM (PWM-Mode) / Curve (Linear) 1000 RPM @ 30-35°C Liquid-temp
-> CPU Core-temps @ idle 38°C / normal 40-65°C / max 79°C
Thermal Grizzly AM5 Contact Sealing Frame
TG-CSF-AM5
Thermal Grizzly PhaseSheet PTM
TG-PS-50-40
GPU COOLING
Sapphire TOXIC AMD Radeon RX 6950 XT Limited Edition Build-in Asetek AIO Liquid Hybrid Cooler (360mm)
11317-01-20G
(3x Front-Intake PULL with Sapphire branded FirstDo FD1225H12D ARGB black - 120mm PC Cooling Fans)
ZeroRPM Fan 35°C Solution (PowerPlayTable @ DeviceProperties)
TG-PS-50-40
Repaste 3.5 years after purchase.
ASUS T_Sensor @ Waterblock
-> GPU Core-temps @ idle 27°C / normal 30-51°C / max 63°C
-> GPU HotSpot-temps @ idle 30°C / normal 46-71°C / max 75°C
SYSTEM COOLING
Thermaltake CT140 EX ARGB Sync white - 140mm PC Cooling Fans
CL-F191-PL14SW-A
(3x Front-Intake PUSH)
Thermaltake CT140 EX Reverse ARGB Sync white - 140mm PC Cooling Fans
CL-F195-PL14SW-A
(3x Side-Intake + 3x Bottom-Intake)
Thermaltake CT140 white - 140mm PC Cooling Fans
CL-F152-PL14WT-A
(3x Top-Exhaust)
Chassis Fans (Intake) @ 700 RPM (PWM-Mode) / Curve (Trigger) 1000 RPM @ 75-95°C CPU Core-temp
Chassis Fans (Exhaust) @ 500 RPM (PWM-Mode) / Curve (Linear) 1000 RPM @ 40°C T_Sensor-Temp
AUDIO INTERFACE
Focusrite Scarlett Solo 4th Generation USB √ Output: Logitech Speaker System Z523 / Input: E-Guitar
PCM0017717-000
Creative Sound Blaster PLAY! 3 USB DAC AMP and External Sound Card √ Plantronics RIG 400HX XBOX Headset with Microphone
0054651191273
KEYBOARD/MOUSE/CONTROLLER
Logitech Craft Wireless Keyboard (Win/Mac)
920-008484
Logitech G502 LIGHTSPEED Wireless Gaming Mouse
MR0076
Xbox Wireless Controller (Robot White)
QAT-00009
(with Xbox Wireless Adapter for Windows)
check my Github page for files and more information
If anyone finds mistakes or has suggestions for improvement, please post them here, thank you
MAINBOARD
ROG-X870E-X
USB-Mapping
U20G_C6 (1)
U5G_E1234 (18)
M.2(WIFI) (15)
USB Audio (6)(16)
CPU
100-100000719WOF
RAM
KF552C40BBK4-128
PCI EXPRESS CARDS
11317-01-20G
(Riser PCIe-Slot)
AC-071-CO1OTN-C1
6871658863422
DISPLAY
S3422DW
534PM
VS145ZJ01
Widgetter (macOS)
STORAGE
Internal
WDS200T2X0E-00BCA0
WDS100T2X0E-00BCA0
WDS100T2X0E-00BCA0
WDS100T2G0C-00CDH0
B0BKL4PQM2
B0BKL4PQM2
External
9948C3
ST8000NM017B-2TJ103
(Slot 1)
ST8000NM000A-2KE101
(Slot 2)
ST22000NM001E
(Slot 3)
MTFDKBK512QFM
CASE
CA-1X6-00F6WN-00
CABLES
B0B4V8T8BD
MK5570
PSU
NZXT C1000 Gold
PA-0G1BB-EU
CPU COOLING
CL-W407-PL14SW-A
TG-CSF-AM5
TG-PS-50-40
GPU COOLING
11317-01-20G
TG-PS-50-40
SYSTEM COOLING
CL-F191-PL14SW-A
CL-F195-PL14SW-A
CL-F152-PL14WT-A
(3x Top-Exhaust)
AUDIO INTERFACE
PCM0017717-000
0054651191273
920-008484
MR0076
QAT-00009
