[ADVANCED HELP NEEDED] X870 + Ryzen 9600X installer ALWAYS hangs at 12 minutes ... out of ideas
realmranshuman
9
Ryzen 5 9600X
Hi everyone,
I’m posting this after exhausting pretty much every reasonable (and unreasonable) debugging path I can think of. I’m specifically looking for advanced insight from people who have worked with AM5 / X870 / Zen 5, because at this point this does not feel like a basic EFI or kext issue anymore.
Hardware
  • Motherboard: MSI X870-P
  • CPU: AMD Ryzen 5 9600X (6 cores / 12 threads)
  • GPU: ASUS Dual Radeon RX 6600 (Navi 23)
  • Storage: Crucial P310 1TB NVMe
  • RAM: Patriot Viper Extreme DDR5 16x2 (No overclocking. Base 5600MT/S).
  • BIOS: Latest available (also tested 1 version back)
macOS versions tested
  • Sonoma
  • Sequoia
-> Both behave identically.
The problem (100% reproducible)
The installer always hangs at “12 minutes remaining”, right after this log line:
Disk: EnsureRecoveryBooter: Exiting operations
No kernel panic.
No reboot.
No watchdog reset.
At that point:
  • Keyboard and mouse are completely dead
  • Screen is frozen
  • No further logs
  • Waiting indefinitely does nothing
This happens on every install attempt, across macOS versions.
What I’ve already tried (in detail)
Install media
  1. First tried Olarila Vanilla images → same hang
  2. Then stopped using prebuilt images entirely
  3. Created full official installersusing:
    • macOS in VMware
    • softwareupdate --fetch-full-installer
    • createinstallmedia to USB
➡️ Result is identical in all cases.
ACPI work
  • Extracted DSDT.aml
  • Located the full ACPI paths of USB controllers
  • Applied NoOp ACPI patches to force-enable USB controllers (UPC / PLD / RHUB)
  • If I disable these ACPI NoOp patches → early EXITBS
  • ACPI SSDTs in use:
    • SSDT-EC
    • SSDT-USBX
    • SSDT-PLUG-ALT
USB
  • Generated USBMap.kext on Windows using Native Classes, following the ChefKiss guide
  • Without USBMap.kext → system waits for root device after AHCI initialization
  • If I disable DevirtualiseMmio → same “waiting for root device”
  • Tried multiple physical USB ports (rear + front + USB2.0 + USB3.0 )
  • Tried different keyboards and mouse
CPU / Kernel
  • Using AMD Vanilla kernel patches
  • CPU core count patches are active
  • Without these → system does not boot at all
  • Core count is detected correctly in logs
GPU
  • Tried multiple GPUs (different brands of RX6600) at a repair shop
  • Allcards behave the same
  • agdpmod=pikera in boot-args
  • Resize BAR disabled in BIOS
  • ResizeAppleGpuBars = 0 in OpenCore
Same hang every time.
OpenCore configuration
  • SMBIOS: MacPro7,1
  • SecureBootModel: Disabled
  • DevirtualiseMmio: Enabled (required)
  • Above 4G Decoding: Enabled/Disabled (Both Tested)
  • npci=0x2000 in boot-args (with and without)
  • Full debug logging enabled
  • Tried both the debug and the release version of OpenCore 1.0.6
Kexts
  • Lilu
  • VirtualSMC
  • WhateverGreen
  • AppleALC
  • SMCProcessorAMD
  • SMCRadeonSensors
  • AppleMCEReporterDisabler
  • NVMeFix
  • RestrictEvents
  • LucyRTL8125Ethernet
  • USBMap.kext
I have tried with minimal and all kexts. Also, just excluding AppleALC.
ACPI / Booter / Kernel
All listed in my attached config.plist (included below).
-> mportant behaviors:
  • Without USBMap.kext → waiting for root device
  • Without DevirtualiseMmio → waiting for root device
  • Without USB controller NoOp ACPI patches → early EXITBS
What I’m asking
At this point, I’m not looking for generic suggestions like:
  • “Try a different USB port”
  • “Rebuild USBMap”
  • “Remove kext X”
I’ve done all of that, repeatedly.
I’m specifically asking:
  • Has anyone successfully fresh-installed Sonoma or Sequoia on X870 + Zen 5?
  • Is this a known installer userspace hang on newer AGESA?
  • Is there any ACPI / power / SMU quirk specific to X870 that macOS chokes on during the installer handoff?
  • Or is this simply not realistically solvable yet without firmware or OS changes?
Logs + EFI + DSDT + List Of Files​
I’m attaching my full EFI + Logs + DSDT.dsl + list of files that installer writes on the NVMe before freezing up, for review here:
Sorry for the long post, but I wanted to make it clear that this isn’t a low-effort or beginner issue.
Any advanced insight would be genuinely appreciated.
