Solved Need EFI for Ventura or Sonoma
faolchu
Ryzen 5 4600G
Hi everyone! Can somebody create EFI for Ventura or Sonoma OpenCore 1.0.2
Ryzen 5 4600G
Gigabyte B550M DS3H
RAM 32Gb DDR4 3200 MHz
SSD 256 Gb
AMD RX560 4Gb
Here is an EFI for your AMD system.
It is based on the EFI I am currently using for my Asus B550M system, but with a few changes to suit your Motherboard, CPU, GPU etc,
Try it see if it works.
Make sure you rename it to 'EFI' before you do.
Nope!
Stuck on stage on photo
I've tried some EFI with Monterey and moved to installation, but it's said "An internet connection is required to install Mac OS". It seems to me that OS haven't seen my Network Card. EFI attached. Maybe it somelike helps
    EFI.zip
By the way, the first word in your reply 'Nope!' was pretty rude considering I was trying to help you.
Oh! I'm sorry for rudeness. I tried to install MacOS something about 6 hours and had not even think how my words would look like. Excuse me please
Have you set the Bios to run macOS?
See this link for AMD Bios settings:
Yep, I did everything of this recomendations but nothing was chanched
