Trying to install MacOS in my HP Pavilion Gaming 15 AMD Laptop
af0209
5
AMD Ryzen 5 4600H
Hi guys! I was trying to install MacOS on my HP Pavilion Gaming 15 laptop, but i cant get it to boot in the installer. Does anyone have a EFI that works with my pc?
Specs:
CPU: AMD Ryzen 5 4600H
GPU1: AMD Radeon(TM) Graphics
GPU2: NVIDIA Geforce GTX 1650 TI
RAM: 8GB
SSD: NVME 500GB
NETWORK: RealTek RTL8822CE PCIe Adapter
I'm sorry to say you are wasting your time with this laptop.
  1. The GTX 1650 Ti is not supported in any version of macOS.
  2. The integrated AMD graphics are not supported either.
  3. So you won't be able to install macOS with any graphics acceleration.
I know, i already struggled with that, i just need ir for school and for adapting my programming language for macOS, i just need to get it installed
You would be better served buying a second hand Intel system/laptop for macOS. Without a Mux switch for the graphics and a macOS compatible graphics card, AMD laptops such as your HP model just don't work.
Whereas the IGPU will work with macOS in most Intel based HP, Dell, Asus etc. laptops.
i tried yesterday, and i got a this mac os version is incompatible with bla bla bla
Use MacBookPro15,4 SMBIOS.
- ExtremeXT
Any success with this? I have lenovo legion 5 amd ryzen 5 5600h with RTX 3060, and also can't install mac..
