ASUS Rog Strix B550-i gaming FIXED
ford224
12
First reboot during Installation of Opencore keeps shutting down and restarting computer.
CPUAMD Ryzen 5 5600X @ 3.7GHz
Motherboard ASUS Rog Strix B550-i gaming
RAM 16GB (2 x 8GB)
Audio ChipsetALC-S1220A
GPU ASUS STRIX RX 6600 XT
WiFi & Bluetooth IntelĀ® Wi-Fi 6 AX200
Lan IntelĀ® I225-V 2.5Gb EthernetOS
DiskSamsung 960 Evo 500GBmacOSBig Sur 11.0.1/ OpenCore 0.6.4 Alpha
https://wetransfer.com/downloads/1c...e4362d0cc940e197feb7032420220827200407/718edd
HELLP all fixed
Pointers:
  1. Using OpenCore 0.6.4 is fine for Big Sur and Catalina, not so fine for Monterey.
    1. As macOS Monterey requires OpenCore 0.7.4 as a minimum for the OS to boot.
    2. Ventura beta requires OpenCore 0.8.3.
  2. Your RX 6600 XT requires Monterey 12.1 or newer, as the earlier versions of macOS don't contain the drivers for the RX6600 cards.
  3. Your Intel WiFi card requires AirportItlwm.kext or Itlwm.kext to work in macOS, never use both at the same time.
  4. The Intel Bluetooth module requires BlueToolFixup.kext and IntelBluetoothFirmware.kext.
    1. Do not use IntelBluetoothInjector.kext when running macOS Monterey.
  5. Your Intel i225-V Ethernet controller can be temperamental in macOS.
    1. It requires a DeviceProperties to fake the ID of a natively supported ethernet controller.
    2. You have to make sure you are using the correct ACPI address when adding this device-id entry.
    3. Plus a boot-arg e1000=0.
    4. On macOS 12.2.1 and below, you have to use dk.e1000=0
  6. Samsung NVMe drives are known to have a Firmware/Trim issue in Big Sur and Monterey.
    1. This causes issues when booting macOS, such that the boot time can be many minutes, instead of under 30seconds.
    2. If you have the option to use a Western Digital, SanDisk or other drive not effected by this Firmware/Trim issue I would recommend you do so.
Can you fix the whole EFI please
Hi @ford224,
I've done all the changes needed using my working B550 Vision D Monterey 12.1 build but adapting to your setup which also includes updates for the RX6600, Intel 6 AX201 WiFi and Intel I-255V ethernet using the new AppleI2xx kext. Please give it a try.
Reactions: Kapsi
Hi @ford224,
Okay, this is really weird and I don't know how common it is, but I have pretty much the same specs as OP and I have been battling with my hackintosh for a couple of days now and while looking for some help I came across this forum and your reply, so I wanted to thank you and let you know that I will be trying this configuration tomorrow morning. You are a lifesaver! ā™„ļø
Great! Just remember to use/generate completely new UUID, ROM and serial data in the SMBIOS section using SSDTPRGen in the EFI config file because that belongs to the OP. As if Apple finds out more than one instance of the same serials are being used on two machines in two different locations they will likely close it down.
Hi @ford224,
Instead of just preparing and giving EFI folders to people, you should teach them how to do their own. If they actually learn how Hackintosh stuff works, they are less likely to need help in the future, and are going to have a better experience when using their Hackintosh.
I’m sorry but that is an incredibly rude attitude you have! I am just trying to help you and asked to test it - the help is not an obligation.
FYI my B550 EFI build is already working for hundreds of users on Monterey 12.3+ > https://www.tonymacx86.com/threads/...-5900x-rx550-samsung-1tb-970-evo-plus.319781/
@ExtremeXT I always tell users to try to edit their own EFI files under my guides (and I have many on Tonymac). FYI the OP was already given advice by @Edhawk to edit but had asked for extra help with it instead. That was where I thought to step in. Unfortunately it seems my efforts are not being appreciated.
@ford224 the path to get a fully working hackintosh is not a possible overnight task. It is a long process of trial and error and testing and yes we do often hit walls even ourselves. I cannot count how many times I have had to reboot my system just testing new settings and parameters.
If your system crashes you need to check what is causing the crash because on a hackintosh there are tons of variables that could cause it. Are the BIOS settings you are using correct ie. hackintosh compatible? Is your GPU compatible with the version of macOS? Have you run the ResetNVRAM tool before running the new EFI build? Are the cables and cards in the PC system properly sitting in their sockets? These are the sorts of things I would check and do.
FYI the EFI build I had posted for you is designed for Monterey 12.1+. It will not work with Big Sur as your RX6600 does not work with Big Sur.
Yes finaly or problem all WIFI or BT not signal WIFI yes
That's a bit hard to discern. You need to check what BT card you have. Do you have an Intel Bluetooth card or a Broadcom BRCM card installed?
For Intel BT, you only need BluetoolFixup.kext and IntelBluetoothFirmware.kext enabled. For Broadcom cards you will need the Broadcom
BT kexts. As I think you do have Intel BT installed you should be fine.
However you will need to make sure that power is going to your USB internal ports (for the Bluetooth).
Maybe you could try to disable USBInjectAll.kext and enable Rog-B550I-USB-Map.kext in your config.plist?
As that was the original USB port map from your EFI.
pls send me configuration bios all
BIOS settings are these:
