bye smalltreeintel in Beta 9
Dam, That won’t do. Stupid Intel ethernet portâ€¦đŸ˜‚
Fingers crossed for beta 10 bringing the smalltree kext back to life in that case but I very much doubt that will be the case. We will need a proper replacement or fix on the smalltree kext Me thinks.
i am not usually using the sleep mode for my pc so its a no big deal for me, as long as this appleigb does not make a connection drop outs.
yeah looking forward on the beta10 and hopefully that smalltree will work again :giggle:
Your lucky, When I think about things like this I don’t think about myself I think as a whole for everybody so generally it breaking via sleep is a deal breaker. For myself I have 2 ethernet ports and use my Realtek 2.5gb port as my primary port and my intel port is disabled so I couldn’t care less for myself as it has no effect on me…lol
Reactions: elixir
:ROFLMAO: i guess you're the lucky one, i have only this i211 port my mini-itx board, if anytthing goes bad for ethernet i have only the wifi :LOL:
Reactions: AudioGod
i got some speedtest results with different speeds settings at manual config:
100baseTX, half-duplex : DL = 43; UL = 14.6
100baseTX, full-duplex: DL 50; UL = 58/xx
1000baseT: DL = 117/118 ; UL = 58.9/59 , MTU- std 1500 and Jumbo 9000 yield same response.
so i guess, i can stick for this kext for awhile.
while hopeful for the smalltree to came alive on beta10
note: the readings above based on my internet plan :LOL::ROFLMAO:
@elixir I’m on an ITX too, I switched to an USB-to-Ethernet dongle for good because I anyway upgraded my network to 5/10Gb/s Ethernet.
There are some options that work well with macOS.
Reactions: elixir
so far it holds on for almost 9hours straight without dropping connections,
im contented for now :)
probably gonna get official monterey on Oct 18 lol (at least a release note??
AppleIGB works for 1-2 minutes at a time on mine then i have to change some settings to get another 1-2 minutes. Really wished I had looked up the issue with Smalltree before upgrading :cautious:. Hopefully something will come out soon to fix this.
Reactions: bja
AppleIGB has occasional lag spikes for a few seconds, but it is usable.
Not on my x570 asrock steel legend, when it dies it dies hard and never comes back (left it for an hour and it didn't come back to life without me changing the hardware in system preferences -> network
