OC 0.8.2 boot issue
Yard Sale
3700X
TLDR: Running stable Mojave/Clover on an AMD Hackintosh. Made a Monterey USB with OpenCore 0.8.2. Boot problem related to NVRAM.
All files downloaded July 4 (OC version 0.8.2 Release). Following the dortania OC docs.
I go into the BIOS boot picker and tell it to boot from the OpenCore EFI on the Monterey installer USB, then restart. It reports this error:
Failed to calculate size of dict field containing <empty> as type integer, context <7C436110-AB2A-4BBB-A880-FE41995C9F82>!
The context is NVRAM. Following is an except from the NVRAM section from my plist. Any help would be appreciated. The strange thing is I had previously got it to boot and reset the NVRAM in the picker, and it hanged after a bunch of verbose logging. But now it does this. I started over creating a fresh USB and it still does this at boot. And there's no NVRAM reset or SIP options in the picker, not even if I press the space bar.
<key>7C436110-AB2A-4BBB-A880-FE41995C9F82</key>
            <dict>
                <key>#INFO (prev-lang:kbd)</key>
                <string>en:252 (ABC), set 656e3a323532</string>
                <key>ForceDisplayRotationInEFI</key>
                <integer>0</integer>
                <key>SystemAudioVolume</key>
                <data>Rg==</data>
                <key>boot-args</key>
                <string>-v keepsyms=1 debug=0x100</string>
                <key>csr-active-config</key>
                <data>AAAAAA==</data>
                <key>prev-lang:kbd</key>
                <data>cnUtUlU6MjUy</data>
                <key>run-efi-updater</key>
                <string>No</string>
            </dict>
        </dict>
        <key>Delete</key>
        <dict>
            <key>4D1EDE05-38C7-4A6A-9CC6-4BCCA8B38C14</key>
            <array>
                <string>DefaultBackgroundColor</string>
            </array>
            <key>4D1FDA02-38C7-4A6A-9CC6-4BCCA8B30102</key>
            <array>
                <string>rtc-blacklist</string>
            </array>
            <array>
                <string>boot-args</string>
                <string>ForceDisplayRotationInEFI</string>
            </array>
        </dict>
        <key>LegacyEnable</key>
        <false/>
        <key>LegacyOverwrite</key>
        <false/>
        <key>LegacySchema</key>
        <dict>
            <array>
                <string>EFILoginHiDPI</string>
                <string>EFIBluetoothDelay</string>
                <string>LocationServicesEnabled</string>
                <dict>
                    <key>APFS</key>
                    <dict>
                        <key>EnableJumpstart</key>
                        <true/>
                        <key>GlobalConnect</key>
                        <false/>
                        <key>HideVerbose</key>
                        <true/>
                        <key>JumpstartHotPlug</key>
                        <false/>
                        <key>MinDate</key>
                        <key>MinVersion</key>
                    </dict>
                    <key>AppleInput</key>
                    <dict>
                        <key>AppleEvent</key>
                        <string>Builtin</string>
                        <key>CustomDelays</key>
                        <false/>
                        <key>GraphicsInputMirroring</key>
                        <true/>
                        <key>KeyInitialDelay</key>
                        <integer>50</integer>
                        <key>KeySubsequentDelay</key>
                        <integer>5</integer>
                        <key>PointerPollMask</key>
                        <integer>-1</integer>
                        <key>PointerPollMax</key>
                        <integer>80</integer>
                        <key>PointerPollMin</key>
                        <integer>10</integer>
                        <key>PointerSpeedDiv</key>
                        <integer>1</integer>
                        <key>PointerSpeedMul</key>
                    </dict>
                    <key>Audio</key>
                    <dict>
                        <key>AudioCodec</key>
                        <key>AudioDevice</key>
                        <string>PciRoot(0x0)/Pci(0x1b,0x0)</string>
                        <key>AudioOutMask</key>
                        <key>AudioSupport</key>
                        <false/>
                        <key>DisconnectHda</key>
                        <false/>
                        <key>MaximumGain</key>
                        <integer>-15</integer>
                        <key>MinimumAssistGain</key>
                        <integer>-30</integer>
                        <key>MinimumAudibleGain</key>
                        <integer>-55</integer>
                        <key>PlayChime</key>
                        <string>Auto</string>
                        <key>ResetTrafficClass</key>
                        <false/>
                        <key>SetupDelay</key>
                    </dict>
                    <key>ConnectDrivers</key>
                    <true/>
                    <key>Drivers</key>
                    <array>
                        <dict>
                            <key>Arguments</key>
                            <string></string>
                            <key>Comment</key>
                            <string>HfsPlus.efi</string>
                            <key>Enabled</key>
                            <true/>
                            <key>Path</key>
                        </dict>
                        <dict>
                            <string></string>
                            <key>Comment</key>
                            <string>OpenRuntime.efi</string>
                            <key>Enabled</key>
                            <true/>
                            <key>Path</key>
                        </dict>
                        <dict>
                            <string></string>
                            <key>Comment</key>
                            <string>ResetNvramEntry.efi</string>
                            <key>Enabled</key>
                            <true/>
                            <key>Path</key>
                        </dict>
                        <dict>
                            <string></string>
                            <key>Comment</key>
                            <string>ToggleSipEntry.efi</string>
                            <key>Enabled</key>
                            <true/>
                            <key>Path</key>
                        </dict>
                    </array>
