Need assistance adapting EFI for macOS Tahoe (Ryzen 9 7950X3D + RX 6900 XT)
hinkin
62
AMD Ryzon 9 7950X3D
Hi everyone,
I’ve been trying for several days to get my EFI configuration working for macOS Tahoe on my system, but I haven’t had any success so far.
Hardware Configuration​
  • CPU: AMD Ryzen 9 7950X3D
  • Motherboard: Gigabyte X870 AORUS ELITE WIFI7
  • RAM: 64GB DDR5 5000MHz
  • GPU: AMD Radeon RX 6900 XT 16GB
  • Network: Realtek RTL8125B
  • Wi-Fi/Bluetooth: Fenvi T919 PCIe WLAN Card
I currently have a fully working EFI for macOS Sequoia, but I need assistance in adapting or fixing it so that it can properly install and run macOS Tahoe on this setup.
I’m sharing my current EFI folder for anyone interested in helping improve or create a Tahoe-compatible version.
Any help or suggestions would be greatly appreciated.
Thank you in advance!
That screen image show 3 x ACPI errors - G02F, G002 & G027.
It means you need add 3 x ACPI patches to your config.plist to fix these issues. Which is a standard issue with all AMD AM5 Hacks.
I'm obviously not as reputable as CorpGhost, but the standard G002 issues are dealt with by the (non-MSI) generic patches in this post.
The G02F and G027 errors are new to me. G02F is only invoked to create a PWRB (Power Button) device, and there's an Else clause which creates a purposedly generic LPWR device instead. G027 does not create any device but dispatches GPE notifications. I would not attempt to patch these as first intention.
Reactions: fabiosun
I started over, hoping I missed something with creating the EFI folder. Everytime I do, when I check with OC Validate there r 3 errors for No schema for HideVerbose at 3 index, context <Drivers>, would that be an ACPI issue?
No, it should be an error in your config.plist in the Drivers section.
posted for you on AMD OSX discord server
sorry i missed your post :)
@etorix
No @PYLZNER you have to wait
that DSDT is yours, CorpGhost didn't do for now the useful patches for you
meanwhile you could try with etorix method, he is also a skilled user in this subject :)
Add them to your config.plist, in the ACPI > Add section.
