BigSur freezing sometimes
TherioN
15
AMD Ryzen 7
Hello!
I have successfully installed OSX BigSur on Gigabyte Aorus X470 Mobo, Ryzen 7 2700X CPU, AMD R9 380 2GB, 32GB DDR4 RAM.
After some time, computer freezes, first I can move the mouse, but then it gets totaly frozen.
Please help, this is what I can see after reset:
panic(cpu 14 caller 0xffffff80159fca25): userspace watchdog timeout: no successful checkins from com.apple.WindowServer in 120 seconds
service: com.apple.logd, total successful checkins since load (1940 seconds ago): 195, last successful checkin: 0 seconds ago
service: com.apple.WindowServer, total successful checkins since load (1910 seconds ago): 179, last successful checkin: 120 seconds ago
Backtrace (CPU 14), Frame : Return Address
0xffffffc10b05b670 : 0xffffff801268c26d mach_kernel : _handle_debugger_trap + 0x3fd
0xffffffc10b05b6c0 : 0xffffff80127d3993 mach_kernel : _kdp_i386_trap + 0x143
0xffffffc10b05b700 : 0xffffff80127c3f8a mach_kernel : _kernel_trap + 0x55a
0xffffffc10b05b750 : 0xffffff8012630a2f mach_kernel : _return_from_trap + 0xff
0xffffffc10b05b770 : 0xffffff801268ba8d mach_kernel : _DebuggerTrapWithState + 0xad
0xffffffc10b05b890 : 0xffffff801268bd83 mach_kernel : _panic_trap_to_debugger + 0x273
0xffffffc10b05b900 : 0xffffff8012e9c824 mach_kernel : _panic_with_thread_context
0xffffffc10b05b970 : 0xffffff80159fca25 com.apple.driver.watchdog : __ZN10IOWatchdog14userspacePanicEP8OSObjectPvP25IOExternalMethodArguments.cold.1 + 0x27
0xffffffc10b05b980 : 0xffffff80159fc660 com.apple.driver.watchdog : __ZN10IOWatchdog35userspaceDisableUserspaceMonitoringEP8OSObjectPvP25IOExternalMethodArguments
0xffffffc10b05b9a0 : 0xffffff8012e1d06e mach_kernel : __ZN12IOUserClient14externalMethodEjP25IOExternalMethodArgumentsP24IOExternalMethodDispatchP8OSObjectPv + 0x1de
0xffffffc10b05b9f0 : 0xffffff80159fba34 com.apple.driver.watchdog : __ZN20IOWatchdogUserClient14externalMethodEjP25IOExternalMethodArgumentsP24IOExternalMethodDispatchP8OSObjectPv + 0x7c
0xffffffc10b05bb20 : 0xffffff8012e2731b mach_kernel : _is_io_connect_method + 0x35b
0xffffffc10b05bc80 : 0xffffff801277f1d1 mach_kernel : _iokit_server_routine + 0x4dd1
0xffffffc10b05bd90 : 0xffffff80126918ed mach_kernel : _ipc_kobject_server + 0x2fd
0xffffffc10b05be00 : 0xffffff8012667c35 mach_kernel : _ipc_kmsg_send + 0x115
0xffffffc10b05be60 : 0xffffff801267f3e2 mach_kernel : _mach_msg_overwrite_trap + 0x2d2
0xffffffc10b05bef0 : 0xffffff80127a805d mach_kernel : _mach_call_munger64 + 0x29d
0xffffffc10b05bfa0 : 0xffffff8012631216 mach_kernel : _hndl_mach_scall64 + 0x16
com.apple.driver.watchdog(1.0)[D6C7D5C2-D05A-3CAD-916A-AAB7D25B1EBF]@0xffffff80159fa000->0xffffff80159fcfff
Process name corresponding to current thread: watchdogd
Boot args: keepsyms=1 alcid=1 debug=0x100 npci=0x2000
Mac OS version:
20G314
Kernel version:
Darwin Kernel Version 20.6.0: Wed Nov 10 22:23:07 PST 2021; root:xnu-7195.141.14~1/RELEASE_X86_64
Kernel UUID: C67468D8-72C1-36BC-A0DA-CD5FA852AD32
KernelCache slide: 0x0000000012400000
KernelCache base: 0xffffff8012600000
Kernel slide: 0x0000000012410000
Kernel text base: 0xffffff8012610000
__HIB text base: 0xffffff8012500000
System model name: iMacPro1,1 (Mac-7BA5B2D9E42DDD94)
System shutdown begun: NO
Panic diags file available: YES (0x0)
Hibernation exit count: 0
System uptime in nanoseconds: 1944351341405
Last Sleep: absolute base_tsc base_nano
Uptime : 0x000001c4b45efe55
Sleep : 0x0000000000000000 0x0000000000000000 0x0000000000000000
Wake : 0x0000000000000000 0x00000018ff5472eb 0x0000000000000000
I uploaded EFI I'm using
may be I need some patch, many thanks for help
