hotplug is working, one user in this thread has confirmed that hotplug is working.
but for me nothing works ๐Ÿ˜…๐Ÿ˜…
It should be installed in the lowest slot. The card will not be lit in the rest of the slots.
In addition, the card was recognized irregularly. I gave up in the end. :cry:
Reactions: CaseySJ
I havenโ€™t been following the rumor mill on this. What new AM5 CPU is coming out?
Ryzen 8000 with Zen 5 cores, in 2024 for desktops. Andโ€”you'll love that partโ€ฆโ€”hybrid architecture with a mix of Zen 5 and Zen 5c cores, at least for some mobile/console CPUs.
I understand that new Threadripper Pro AM5 will be announced in about a week, but may only be available to OEMs.
Probably "Lenovo exclusive" for 6 months or so before being available at retail, like the 5000WX.
Reactions: CaseySJ
@CaseySJ @Shaneee
sent also via DM a video @ExtremeXT to take a look when he has time to dedicate to this
Curious if it is only a my problem with hero and my config/EFI
Reactions: leesurone
@CaseySJ @Shaneee
Ouch, looks like DSDT and many system SSDTs are failing to load.
Regarding DSDT, macOS cannot find: \_SB.PCI0.GPP7.UP00.DP60.XH00.RHUB.POT6
Do Windows and/or Linux work with this BIOS?
WIndows 11 is perfect
now i am creating a UBuntu USB live to see
Yep also ubuntu is working well
In the past we created a patch for Gigabyte DSDT problems. Now for Asus it seems we may also need to create patches for DSDT and some system SSDTs.
I assume macOS boot process freezes shortly after those ACPI errors are displayed?
@CaseySJ this is verbose i see
maybe it is safe to wait to another bios release version if this problem will be confirmed also from others AM5 users
Looks like it possible your BIOS update has renamed some stuff. I remember this happening when using a full DSDT in the system which is why SSDTs were used more often.
Can you post all of the ACPI tables? This can be done by using OpenCore.efi debug binary and setting config.plist -> Misc -> Debug -> SysReport to True. Then ACPI files will be in "SysReport" folder located in root folder of EFI partition.
Here you go also with debug log
1602 good for all OS (osx, windows,Ubuntu)
1709 not good for OSX
Yup. The DSDT has been restructured.
Old version:
External (SB.PCI0.GP17.VGA_.AFN7, MethodObj) // 1 Arguments
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP60.XH00.RHUB.GPLD, MethodObj) // 2 Arguments
New version:
External (SB.PCI0, DeviceObj)
External (SB.PCI0.DADR, IntObj)
External (SB.PCI0.EBUS, IntObj)
External (SB.PCI0.FLG0, IntObj)
External (SB.PCI0.GP17, DeviceObj)
External (SB.PCI0.GP17.ACP_, DeviceObj)
External (SB.PCI0.GP17.AZAL, DeviceObj)
External (SB.PCI0.GP17.VGA_, DeviceObj)
External (SB.PCI0.GP17.XHC0, DeviceObj)
External (SB.PCI0.GP17.XHC1, DeviceObj)
External (SB.PCI0.GP18, DeviceObj)
External (SB.PCI0.GP19, DeviceObj)
External (SB.PCI0.GP19.XHC2, DeviceObj)
External (SB.PCI0.GPP0, DeviceObj)
External (SB.PCI0.GPP1, DeviceObj)
External (SB.PCI0.GPP1._ADR, IntObj)
External (SB.PCI0.GPP2, DeviceObj)
External (SB.PCI0.GPP3, DeviceObj)
External (SB.PCI0.GPP4, DeviceObj)
External (SB.PCI0.GPP5, DeviceObj)
External (SB.PCI0.GPP6, DeviceObj)
External (SB.PCI0.GPP7, DeviceObj)
External (SB.PCI0.GPP7._ADR, IntObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.UHBS, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C1, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C2, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C3, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C4, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C5, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6C6, FieldUnitObj)
External (SB.PCI0.GPP7.UP00.DP40.UP00.DP00.WIFI.W6GS, FieldUnitObj)
External (SB.PCI0.GPP8, DeviceObj)
External (SB.PCI0.GPP9, DeviceObj)
External (SB.PCI0.GPPA, DeviceObj)
External (SB.PCI0.GPPB, DeviceObj)
External (SB.PCI0.GPPC, DeviceObj)
External (SB.PCI0.GPPD, DeviceObj)
External (SB.PCI0.GPPE, DeviceObj)
External (SB.PCI0.GPPF, DeviceObj)
External (SB.PCI0.GPPG, DeviceObj)
External (SB.PCI0.GPPH, DeviceObj)
External (SB.PCI0.M641, IntObj)
USB is now under GP17 and GP18; GPP7 has taken WiFi over. Need to re-do SSDTs for macOS.
Have you posted your current EFI somewhere?
Reactions: fabiosun
Old version:
New version:
i use only these two
Reactions: unforsaken
On closer look, it's worse than I first thought. The USB objects under _SB.PCI0.GPP7.UPP0 which your SDDTs want still potentially exist under GPP7: In the new DSDT, their creation is now conditional upon various parameters (G002, G000, G003, G004). AMD may be preparing to introduce various tiers of CPUs with different capabilities.
And the first error in the screenshot is a failure to load the the DSDT itself. MacOS may have trouble with this conditional code.
If the only error that is preventing DSDT from loading is due to the highlighted error...
... then the missing ACPI path \_SB_.PCI0.GPP7.UP00.DP60.XH00 is conditionally defined by this:
As we can see, there are 3 conditions:
C:
    If (((G002 != 0x03) && ((G000 == One) && (
        G004 != 0x43FA1022))))
We could create an ACPI patch to change any or all of the conditions. Fortunately there are no other references to PCI0.GPP7.UP00.DP60, which means we don't have to worry about a conflicting device tree being created at the same path.
@CaseySJ have you update your Gene?
i am curious if it is a general problem or user problem!
